K
kingeri
Been doing a general tidy up job following an EICR, the customer has drilled a hole in the living room floor to feed all the data, SKY, phone etc. cables down from where they come into/converge in the living room. They did this so they could have their router out of the way in the cellar. It's a tidy DIY job! Problem is, they emerge in the cellar directly above the CU, and the cables are totally intermingled with all the T&E, actually wrapped around it in some cases. There is so little room to play with, and I have pointed out that it's not great to have this arrangement. Now, I can't re-route any of the mains cables without getting involved with extending circuits etc., and they won't go for that anyway. So, is there a way of shielding the data cables so that they can remain in close proximity?
If you shielding can you see all data cables, entering and leaving if so re route if not you only shielding what you see????
I would suggest that having advised the customer that the routing is not ideal and him not wanting to alter it, carry out the rest of the 'tidy up' and write it on the MWC/EICR that you have identified the issue. If problems occur in the future with the data transfer, then you may be called back (and paid) to do the segregation of the two classes.
It happens, never even installed new cables just few extra spots lights and added dimmer and the phone went cuckoo buzzzz , on further investigation I found they were always tangled
It happens, never even installed new cables just few extra spots lights and added dimmer and the phone went cuckoo buzzzz , on further investigation I found they were always tangled[/QUOTE]
Dimmer.
There was dimmer their before , I just added new white one and the extra lights must of caused this, anyway she was annoyed
Ideally I'd re-route, but it's just not that easy, you'd have to see it. I think I'll just move them as far apart as I can and leave it at that. Thanks guys.
how about skicking some plastic trunking around the sensitive cables, this would work, if you can run mains cables and data cables together in a dado trunking with just a bit of plastic compartment between them then sticking some yt2 or 4 etc around the phone cables and coax cables would work, regardless whether it could be fixed to the wall or not, if it is around the cables where they are within 6" to a foot of the T&Es then you would have mission accomplised My friend :rockon:
You could put some spiral wrap around the offending cabling but it doesn't sound like it would be an electrical issue as it is now so I would just leave it. As soon as you mess with it it will become your responsibility from now until the end of time as far as the customer is concerned. Six months from now you'll be getting calls because they're not happy with the picture.
