Discuss Should we use copper blade crimps? in the UK Electrical Forum area at ElectriciansForums.net
aaaaaaaaany decent scouser would have nicked the hydraulic tool and flogged it before you could finish your tea.:D:D:D
Reply to Should we use copper blade crimps? in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Hi, I was wondering if the wylex/Proteus SPD Isolators where dual isolator, they have 4 terminals at the bottom, can you use them to take 2 sets...
Joining niceic and doing a sub main to a garage off a tns earthing arrangement using 6mm Swa. The question is I have 25mm tails on 100a main fuse...
I've been carrying out quite a few domestic extension first fixes recently which involves providing a power supply installed from the properties...
