so have you conceded? Have I ground you down into submission ? I learnt that move off my mrs she's a pro.
Conceded what?
This post does not in anyway contradict any previous post that I have made.
You just think that it does.
Quite funny really considering that you spent so much time and effort attempting to prove me wrong on the other thread, and here you are liking this post, which says the same thing as I said on the other thread.
Ha ha...you tell me.
isn't main where the earth is connected near to the stop cock where the water comes in the house, and supplementary where the rest of the water pipes are linked together?? However, with how the original shower cold feed pipe was earthed into the earth from the shower it could be main bonding, or am I digging the hole bigger.
aarrgg!! stop it Bobby!!...its bonding not earthing for extranious mate.....
Conceded what?
Can I be 100% honest I read it wrong, I was half watching tv. Spin I disagree with you again, rcd protect it, we rang Mira last time we had this conversation and they said it must be rcd protected, unless the Mira rep got it wrong as well, I'll ring triton tomorrow :2guns:
That's supplementary bonding your main equipotential bonding is your 10mm to your incoming services normally gas and water sometimes a few others, your 4mm earth in the bathroom connected to the shower and possibly the lighting is your supplementary bonding which is now not required if your con unit is rcd protected
Thanks mate, glad that's cleared up! PHEW!!! All them earth wires look the same to me
aarrgg!!..G/Y...some of them will be bonding conductors which are all about limiting the value of touch voltages...
earthing conductors are all about the duration....
It doesn't really matter what the MIRA rep said or didn't say in the phone call, which I believe was not a phone call but an Email.
If the instructions which are provided with whatever shower is purchased do not state what the rep states.
Even if the instructions do state exactly what the rep states, BS7671 requires that the instructions be taken account of.
I know the answer I have put in at least 20 posts relating to showers already yes they do.
Thanks everyone anyway.
i can see I've opened an old can of worms for some...
I will probably just leave it as it is and have a slightly increased risk of being electrocuted, as it obviously isn't acceptable to just illegally bang an RCD unit in the loft as I assumed would make it safer.
Cheers All
You could put a RCBO in at the DB though? what make of Dist board have you got? Make sure a spark Does it though.
Cheers All
Why not get an electrician in? Then you don't have to take that risk of electrocution.
Cheers All
sore point, no never. Spin loves it
