Hi everyone
Called to a heating system not working correctly, boiler fine, mid-position valve in place. Boiler not firing up all the time, initially thought it could be a faulty mid-position valve. However there seems to be a problem with the receiver! When turning room stat up some times I get 240v when calling for heat from reciever to white cable on valve and then the next minute nothing, has anybody else had similar problems with these? I've coupled the hand unit to reciever and when stat is turned up / down the correct lights light up, its just not giving me 240v all the time.
Any advice greatly received thank you in anticipation.
Steve
Steve
