A
AyresomeBoro
I'm currently working in a school following up on an insurance report and for the 2nd year running the guy that conducts the report has noted that the fused spurs for some of the hand dryers slide on the tiled finish of the toilet walls when you apply a little pressure.
I believe the installation was poor as the metal boxes in the wall are just 'floating' - more than likely just held in place by the conduit. This means that it doesn't matter how much you tighten the screws the fused spur will always slide (a little) on the tile.
I'm almost certain I have seen rubber 'gaskets' that sit in between accessories and tiles in kitchens before?!
Went to two wholesalers today and neither could help me.
Can someone please tell me I'm not going mad and they do exist :confused5:
Cheers!
metal sockets/switches often come with plastic gaskets. their primary use is to prevent moisture in the plaster from corroding thew accessory. they may help. alternatively, bung some gripfix round the back boxes.
