Discuss Size bush and lock ring in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Can anyone tell me what size bush and lock ring you need for 4 25mm tails and 16mm G/Y? For a snug fit
Or is there a 3phase tail gland out there?
Ive not seen one that is all combined but you can get a 4 way gland and put the earth in its own gland.
Wiska one has a smaller hole for the earth through the middle. If the enclosure is ferrous I'm sure the requirement is to bring the cpc through the same entry as the live conductors.
Bringing all 3 phase and neutral through the same gland/hole. CPC can be different gland/hole.
Edit: I'm going to hold my hand up on the above. Be a man, don't delete it.
Just read 521.5.1.
I was wrong.
Just read 521.5.1.
I was wrong.
10 cheesecakes docked from pay.
So would terminating the earth onto a through bolt on the DB and then having another earth terminated on the other side be suitable?
Reply to Size bush and lock ring in the UK Electrical Forum area at ElectriciansForums.net
Incoming supply on our job comes into the building and then the tails from which go into a switched isolator with 200A fuses fitted. No idea...
I bouught a Nissan Townstar EV and have found what I consider a theft problem All previous vans I have had allowed the driver to enter and exit...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
I have a customer that requested kwh meters on the socket circuits of an office lock he rents out,(rooms are rented separately). There are two...
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
