Rockingit
Mentor
We've got 'standard' 40/10 FTTC fibre into a Sky SR203 router, which all works fine and we get speeds around 38/8 at the Sky Router. I've laid CAT6 to an outbuilding where it's connected into a Netgear Nighthawk r8000 predominantly to run some security cams that the WiFi just won't leap as far too, even with extenders. Sky Hub is acting as the DHCP server in the 192.168 range, R8000 has auto-sensed bridge mode and self assigned itself to the 10.0 range - and it works, there's three devices running off it now.
Except, the R8000 is reporting a speed of 8MB/700Kbs, which just can't be right, and it's affecting the security camera streams. It should either be 100MB LAN speed(ish) or at worst a tiny reduction of the Sky speeds, surely?
So what's throttling it - Sky or Netgear?! (NB, the CAT6 is fine, fully tested with my trusty data tester).
I may be wrong but in this configuration both routers must have bridge option, both needs to be connected LAN-LAN, configure first router to act as dhcp and second router dhcp is off.
On the secondary router
turn off dhcp
if your main router is using say 192.168.1.1
its dhcp scope will start at 192.168.1.2 change it to start at 192.168.1.10 to give some spare numbers that will not be automatically assigned
set the ip of the second router to 192.168.1.2
make sure the link cable from router 1 to router 2 is from lan port to lan port. It will allow full speed traffic from lan port to lan port but may not allow speeds that fast through its wan port.
Sorted. Thanks all.
@James - try as hard as I could, your suggestion just wouldn't fly - the R8000 just won't bridge via anything other than it's WAN port it seems and wouldn't pass traffic back to the DHCP server for assignment.
@plugsandsparks - yep, that's what I ended up doing and it's working perfectly, even added an additional guest wifi that it seems the Sky Hub won't do. It'll only do one bit of the garden and my man-cave though, but it's the principle!
Glad the principle is sorted. It you want to give the wifi some serious grunt. Ubiquiti do a range of indoor and outdoor AP and i can say their throughput is pretty good. The outdoor ones i have launched over 40M with full speed at 5GHz
I use comms express for sourcing
Glad you rate Ubiquiti stuff. I've just bought one of their outdoor APs to replace a failing existing one.
