Discuss slow down speed of AC FanCoil blower motor in the DIY Electrical Advice area at ElectriciansForums.net
ilcaa72
hello, i have a central AC Fan Coil with a 3 speed motor within my Condominium. I run the fan of low but find it blows too much air and produces too much noise when i run the AC (the motor works perfectly and doesnt make noise internally, just the rotation and airflow it produces for my samll condo unit) i just dont want to hear the central ac fan running so loud when ac is on
my question is what can i do to control/lower the speed of the blower motor (again, its a 3 speed motor and I only run it on low)
would adding a resistor inline do the trick? is there a device that can run between my 120Volt wire and the low speed wire on my blower motor?
its a 120Volt, 1/5 HP 3 speed ECM motor
any ideas would be appreciated
Reply to slow down speed of AC FanCoil blower motor in the DIY Electrical Advice area at ElectriciansForums.net
i had a 3 speed blow motor to an AC fan coil unit. I disconnected the wiring and installed a new unit and forgot how the wiring goes, i no expert...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
Has anyone taken apart their & self repaired it? 2013 Dodge Grand Caravan SXT - Mileage: 112223 - DTCs - P0480 cooling fan. Also codes in TIPM...
Mileage: 112223 - DTCs - P0480 cooling fan. Also codes in TIPM P0691, P0692 for cooling fan control circuit. Tests/Procedures Performed: 1...
Hi Forum Members I have a 4 pole single phase 240VAC 315 watt motor from a central heating heating system that I think is bad. It's the room fan...
