Discuss Smeg oven advice? in the Electrical Forum area at ElectriciansForums.net
Ross1
Evening guys,
Ive got a smeg under unit oven. Everything is working apart from the heat when the oven is turned on. The fan and light come on but no heat. I'm no good with appliances, but I'm guessing the element. Can anyone tell me a test I can carry out to identify the problem?
Cheers fella's
Do a continuity test on the live an neutral of the element if it's good u should get a low ish reading depends on wattage usually when ****ed u will get no reading at all
Reply to Smeg oven advice? in the Electrical Forum area at ElectriciansForums.net
