Discuss Smoke coming from electric meter/fuse box area in the UK Electrical Forum area at ElectriciansForums.net
Rewiring may be required if cables are damaged - which as @telectrix says - testing and inspection should show. You know of one fault and that may need some cable to fix, but that doesn't mean it's all unserviceable. Have you checked these guys are registered to do electrical work on domestic properties?
Competent Persons Register | Home - http://www.competentperson.co.uk/
Make that 3 faults known about. 2 dead sockets & the landing light circuit (Only 24v on circuit).
So what do you guys think we should have been charged for the work carried out? Replacing the CU and fixing and breaking another 2 gang socket??
were these the 2 electricians?
New posts
Reply to Smoke coming from electric meter/fuse box area in the UK Electrical Forum area at ElectriciansForums.net
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
I didn't get a picture so will have to wait until I go back again but I've done a crude drawing of what was there. Its in a commercial set up...
Hi all, I am an experienced DIY electrician and I just wanted to ask a quick question about something since I am new to this forum, if it hasn’t...
Hi everyone! Im not an electrician but just a guy looking for a possible answer before I call my electricity supplier. Every month without fail...
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
