Discuss socket heights in the UK Electrical Forum area at ElectriciansForums.net
Hey guys.
Is there any regs for distance between sockets and windows? I know that its 450 to the bottom and 120 to the top but never really come across the question of near windows...?
as long as the cable/s are in safe zones, wherever you want. bear in mind that the 450-1200 rule applies only to new build.
Thanks. They want it all up to current regs for disabilities etc. it is an old pub and they have purchased it and converting to a house. The question was raised about windows and its something ive never been asked before so had a quick look and couldnt find anything. In a kitchen Is it still 1200? Even with a 900 work top?
150mm above the work top is the norm not 300mm
I understand its not a new build but they have requested for heights of sockets and switches to meet new build regs. They have asked the question as a new window is being cut in. I follow the general rule of 150 above work top as it sits better for tiling. Eventhough there is that many different size tiles out there now a days
Part M of the Building Regs, page 69:
http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADM_2004.pdf
Then minimum of 150mm from centre-line of socket to top of worktop which will put the bottom of the socket about 100mm above the worktop - any lower and the "worry" is that it will force the cable on the plug into too tight a radius etc.
As to how close to a window then one consideration is that if too close you might end up breaking the corner of the reveal off when chopping the box out! Then you might find you're cutting through the plasterer's galvanised angle bead.
Reply to socket heights in the UK Electrical Forum area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
2nd fixing some sockets in an office today and we were talking about high integrity earthing, I've not got a clue what the sockets are going to...
