Discuss Socket overload danger? in the UK Electrical Forum area at ElectriciansForums.net
I've been humming T Rex for the last half hour?......it's boring.
Me I funk, but I don't care, I ain't no square with my corkscrew hair............???
The textbook solution would be to put in a separate extra single or double 13A socket as you say. This would however be a messy operation involving a plasterer / decorator in addition to an electrician. The question is therefore:
Is there a less-than-ideal alternative "solution" that I could adopt which would nonetheless be an improvement over the Heath Robinson extension lead arrangement that I have been using over the past decade or two? On the basis that the most powerful single appliance that would be used at any one time would be the 3 kW kettle, and I would intend not to have this on at the same time as the "965 - 1150W" toaster.
in your first post you said that the cooker switch was always off. this indicated that it no longer powers a cooker, so you could change it for a double socket.
Sorry if this was ambiguous. The reason that the cooker master switch itself is almost always "off" is because I use the microwaves instead of the cooker (!) Once in a blue moon I would switch the cooker on. The socket in the console next to the cooker switch is what I have the extension lead plugged in to.
Reply to Socket overload danger? in the UK Electrical Forum area at ElectriciansForums.net
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
Hello. I'm in the UK, and have some questions/concerns about my kitchen set up. So the fuse box has 4 breakers/circuits for the kitchen (the...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Recently my RCCB keeps keeps tripping intermittently. It can happen between several hours to few days when a trip will occur. During the trips, no...
4K
