Hello Guys, just a quick question: How would you wire sockets that is build into headboard in the bedroom? I have seen people using flex cable and using fused socket plug plugged into the sockets behind headboard. Same things they did with lamps. They used flex cable and 3 amp fused socket plug that plugged into the socket behind headboard. Can you please advice if its safe to do or it might have issues? Thank you in advance.
How you describe is fine - but it can be difficult to terminate the cable cores into terminals designed for larger solid conductors. So as a minimum you will need ferrules for most fittings, some with box terminals might be OK without.
EDIT: You will need strain relief where (for example) a cable comes out from behind the headboard to be plugged into a socket.
Using flex with fused plug for lamps or built in sockets is pretty normal for headboards and way easier than hardwiring everything.Main thing is making sure the flex is protected from getting damaged behind the bed.
