pc1966
Has anyone here got experience of doing a soil / earth resistance survey for the design of a large-ish site? We might be looking at a fenced area of 150 x 40m or so with possible need for lightning protection and/or input to the decision to have the substation within the site or far enough out that hot/cold separation of LV/HV earths is possible.
I was thinking of getting the Megger DET4TCR2 and their ETK100 probe kit (though a bit galling how much they charge for a few reels of wire and some spikes!) if this is likely to happen as we would need it at a few stages: design, initial testing, and then on-going checks on earth electrode impedance, so longer term its probably better than hiring. But have no experience of those 4-electrode testers to know the good, the bad, and the ugly.
TL;DR any helpful suggestions on measuring soil impedance profiles?
I used 9mm earth rods with a right angle bend on the top and earth wander leads suitably sleeved to denote the different positions, worked out a lot cheaper: 9mm x 1200mm Earth Rod (3/8" x 4ft) - https://www.tlc-direct.co.uk/Products/TLER.html the unit was a PeakTech 2700 only a three probe unit though: «PeakTech® P 2700» Digital earth tester, 0-2000Ω, CAT III 1000V | P 2700 - https://www.peaktech.de/uk/PeakTech-P-2700-Digital-earth-tester-0-2000O-CAT-III-1000V/P-2700 I still have it, but no use to me anymore, may be of some help to you if you need it.
pc1966
Dundee
United Kingdom
Electrical Enthusiast (Unqualified Hobbyist etc)
Soil earth resistance survey
pc1966,
Mike Johnson,
