O
olietaylor97
I would like to put foam acoustic panels all over the walls and ceiling of a room to soundproof it, here are the panels:
View: https://www.amazon.co.uk/A2S-Protection-Acoustic-Soundproofing-Fireproof/dp/B01GAMP2S6/ref=sr_1_9?dchild=1&keywords=fireproof+acoustic+foam&qid=1590420176&sr=8-9
The room has a water metre and gas metre (though there are no gas appliances in the property) in it.
I was going to use this to attach the panels to the walls / ceilings:
View: https://www.amazon.co.uk/Everbuild-CONSPRAY5-Stick-Contact-Adhesive/dp/B0012RZA3C/ref=sr_1_2?crid=1LSE5SCODZ852&dchild=1&keywords=stick+2+contact+adhesive&qid=1590420394&quartzVehicle=72-1783&replacementKeywords=stick+contact+adhesive&sprefix=stick+2+%2Caps%2C149&sr=8-2
I have attached some pictures to help with your verdict.
We have lived at the property for 2 years and the only problem has been mould and damp.
My question is is it safe to install these panels??
Many many thanks for your help!
Olie
I think you had better say what is you plan to do in there first as to whether it is safe. No hanky panky I hope? Shame about the chair though a beautiful example of exquisite workmanship.../sigh. Anyway no I would say there is no fire protection for under the stairs and the likelihood of increasing the hazard is high with foam. Plus you have gas there so I would say a potential fire hazard of the highest order especially if you are thinking sound studio with electrical equipment.
Hi Vortigern,
Thanks so much for your quick reply, super helpful!!
Hahaha yes a music studio, mostly for drum kit practice.
Ah well it's for the best. I just wanted to check, the foam panels say they're fireproof, in their description it says they're Grade 2 Usa standard (?) Does that have any bearing on things?
Once again, really appreciate your professional advice!!
also doing that would spoil the fun of annoying the neighbours , playing drums at mega decibels. :p :p :p
You've got what looks like a boarded out wall with a hollow void where the water meter is, and plain wooden stairs above so I doubt that you would achieve much in the way of soundproofing.
anyway, playing the drums in a confined space, you end up like Brian Johnson (we're not worthy), almost deaf.
In the info on the site it does state:
Product Information
Ideal to SOUNDPROOF: Recording Studios, vocal booths, home entertainment theaters and control rooms | Notification: The acoustic panels are FIREPROOF grade2 according to the USA standards (They do not fuel a fire).. They stop burning after the fire source fading.
olietaylor97,
pirate,
