Discuss Spots in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
ant2781
Hi,
Misses wants me to install two lights in the same room (its big). But only have ONE light switch which turns both lights on. So my plan is this. Please correct me if im wrong.
1) One ceiling rose with a power source to it.
2) Live down to light switch, switch live to turn light on.
3) One netural from ceiling rose 1 to ceiling rose 2.
4) A live wire from switch live on ceiling rose 1 to ceiling rose 2.
Sounds good?
I've done numerous small electrical jobs, change lights, install new light in loft but never took an out fittin out and replaced it with two new lights.
I've even done a nice piccy.
Cheers Ant.
i'll have you know chaps that took me ages to draw!! lol :D
Right off to get some bits now....no doult the misses will want it doing tomorrow!! Cant have a weekend doing nothing now can we?
Reply to Spots in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
  • Locked
I've wired up my spots however the main light [the one that was once a ceiling rose] works as intended with the light switch, but the rest are...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
