B
bobby101
hi all i would like any advice on starting up on my own.
1. where do you recommend i get registered (scotland) select or other who is the quickest ?
2. also what do i need from the tax man ?
3. should i register for vat ?
4. whats the going rate approx, i have an idea but just want confirmation ?
5. what kind of overheads should i expect to encounter ?
6. self employed or limited co
7. any info would be greatly appreciated
I think you can only register with either Select or NEICIC
You should inform the taxman the minute you start up but I think they give you a time period but best to tell them right away plus keep good records
If your turnover is mor than £76k then yes
Thats the $60k question
Well with the motor you can either claim milage or expenses ie depreciation running cost excluding private milage
Its up to you
Hope it helps
