DONES
Hi there,
What would you recommend?
Working on a new build where we are chasing block walls to fit steel conduit to feed outlets as per spec. The ceiling is roughly 4.5 m high and therefore the drops are quite long and as its steel, will be quite heavy. To support the drops, I was thinking of either chasing a little wider in order to fit saddles/ using the saddle only without the base and hammer or screw fixing/ or using the hammer fixings that I'd use with fixing plastic pipe.
Would anyone have any recommendations or experience on this one.
Cheers.
Hi there,
Cheers.
Screwed saddle tops my friend
Cheers for the advice.
I was worried about keeping the pipe straight to line up with the box when hammering in those crampets, though drilling and plugging would sort that out.
I'll try both and see what suits best.
Regards,
DONES
Regards,
DONES
fit the box to the conduit before you fix them to the wall
Regards,
DONES
Thats what the ol' Gary Neville's for mate
You do have one right? :tongue:
Agree, crampets using raw plugged drilled holes. Not as if the crampets are going to be taking any strain for too long, the mortar/plaster filling the chase will be taking care of that soon enough!!
If it's a new build, the mortar on the block work will be fresh so bang them into that, no need to drill and plug. As E54 says, it's only temporary until the plaster or dab
