Discuss Storage heaters in the UK Electrical Forum area at ElectriciansForums.net
Got a question regarding storage heaters and economy 7. Customer wants 7x storage heaters (Elnur Ecombi High Retention) installed in a HMO. Each room has its own 4 way consumer unit per room (basically small studio flats) the only thing is the storage heaters require a 24hour supply and economy 7 supply but only has one neutral terminal. Im going to get the customer to have their providers install an economy 7 switch in each of the flats but its got me thinking... the new economy 7 rcd consumer unit I install with will surely have issues with shared neutrals from the 24hour supply seeing as there is just one terminal or am I going crazy?
Where is the dislike button as i would like to press it on all buzz responses. Storage heaters are one of the cheaper ways of electrically heating a living space, the landlord is offering a cheaper way of heating the studios to tennants at a greater expense to his/herself. Often landlords now get advised to put in high efficiency storage heaters after an epc on the property.
With regard to the neutral terminal i have only ever seen separate terminals within the heaters.
Reply to Storage heaters in the UK Electrical Forum area at ElectriciansForums.net
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Hi Guys, Had a call out today about an odd issue with a newish Creda DT storage heater. Basically.. Storage heaters were installed in one flat...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
