E
ezzzekiel
managed to put a direct short across incomming L/N, and lost power, tested back to service fuse which was ok but i was getting 240v across L/N but as soon as i put a load on it dropped to about 110v, initial thoughts were id lost a neutral so rang dno.
Rapid response came out checked fuse - ok went next door where there was a 3 phase head and he also suspected a cable fault.
Linesmen came next (expecting road to be dug up) however the property was bunny hopped from next doors 3 phase head through a 40a fuse.
the fuse hadnt blown but was showing a high resistance, once replaced it was fine.
me and the dno guys couldnt understand how the fuse was sort of working yet not.
rapid response time is always between 1-3 hours, first guy arrived within the hour then took the full 3 for the line guys to show
Strange one , you talking about me lol , odd more like , had one a few years ago where all the lights were flickering in a shop , tested supply and it was down to 175 volts this was due to a blown fuse at the sub station
Did you realise you'd balls'd it up quickly and d/c? Is it possible that the fuse burned out only a tiny bit, like half a mil, and the current was subsequently arc'ing inside the fuse? Probably not.
yeah mate i realised as soon as the 100a main switch blew up :)
just always figured the fuse would be working or blown but not hanging in between.
