There are no statutory depths for underground cables, as ground levels may have changed since the original installation and without the knowledge of the cable owner. However, there is guidance available from HSE. Guidance is also available from the street works industry's representative body (NJUG) and the Energy Networks Association (ENA) . The ENA also provide contact information for anyone planning excavation work, see: Dial before you dig .
Click HERE
537.2.1 actually - I think I found it. Being REALLY thick sorry - of course every circuit needs an iosolator. In a light it is the switch and in a socket it is the switch etc etc. So obviously a fixed piece of equipment needs a switch.
Table 53.2 tells you what kind of isolator you need for various things. DUH!
This could be by means of the MCB in the consume unit! not a local isolator
Most of the items you are talking about are detailed in the Electricians Guide to the building regulations, for instance section 5.7 covers the depth of buried cables and marking tape.
Admittedly where they get this information from is a fog of unknowledge:confused:. Certainly a lot of it is not referenced in BS7671.
However it is guidance to adhere to when someone is asking uncomfortable questions!
ed-ectrician,
Richard Burns,
