Currently reading:
sub main started.
Discuss sub main started. in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
new sub as existing 3phase board is full. this is the job that glenn's with me on. just got the first 3 single phase circuits in. waiting for location of 3 phase supply before getting cable in.
Sorry Tel got to go lad's just turned up, I will check in later!!
just thinking... should it be called a sub-main? reason it query this is because a sub-main by definition is fed from a OCPD in a main DB. in this case, the tails are going to be split before the main DB and fed direct from the meter, so really, i will have 2 main boards, a sub is fed with that SWA with the missing gland .LOL.
I was looking at the 5d mark 111, but a bit pricey nearly 3k, that's with a lens or 2,300.00 for body only.
just for you, darkwood. earthing nut and fly lead fitted. tails in, waiting for tomorrow to power down and split incomers. existing board is well out of balance. phase currents varying from 16A upwards. 37A in the N. might try and get then to pay a couple of hours to reconfigure some circuits to balance the board.
Now all you need to buy Tel is a Label printer :nono:
Ok let you off then!!
Reply to sub main started. in the UK Electrical Forum area at ElectriciansForums.net
