Discuss supervisor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hey Bon.
1. If you are an employee of a company then you would need to get that company to put you forward to NICEIC/ECA as qualified supervisor. NIC/ECA would then inspect your qualifications to make sure you meet their requirements and add you to the list of Q.S for that company. You could then add this to your jib card.
2. If it's your company then you need the company to join the jib first which can be a nightmare to be honest as you are then bound by their T+C's which are nonsense IMO. Obviously if you are already a member of NIC or ECA you will already be registered as a QS, ad jib will put this on your card, no problem without any other inspection needed.
hope this helps:D
i was wondering how do i go about getting my supervisor certificate i have seen various jib cards with this on do i need to go on a course ?
I am a bit confused, what supervisor certificate are you talking about?
Are you talking about the QS for signing off NICEIC certificates?
If you are then you have to be employed by the company to carry this work out as it is not a qualification in it's own right, to be a QS you need to have 2391-01 Inspection & Testing before NICEIC will let you become one.
hi ian
i did not know if you needed to have passed a test in order to have a jib card with supervisor on it i have seen many over my years as a spark and wanted to try and get out of the manual side of sparking and do more in the desk type of work
if you look at lennies reply all will become clear i think
Reply to supervisor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
There's been a few changes recently at the company I work for. 2 electrical supervisors and the contract manager left towards the end of last...
I have been working as an electrician under an NICEIC Approved Contractor for the past 10 years. I have my C&G2365 level 1/2/3 (acquired before...
Hello, We changed plans with lighting in one zone. Now instead of 4 downlights (square shape of 1400mm side) we want a chandelier. Since...
I’ve been in the Fire and Security Industry arounf 3 years now and have my qualifications. I was given an Install of a Panel change and Keypad and...
Hi Guys, I’m going down the experienced worker route in electrical installations and wanted some advice regarding a cscs card. I’ve spoke to the...
