Discuss swa- amd3 in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
can you get fire retardant swa cleats?
for installing swa in a escape route that doesn't have a false ceiling etc
or would it just have to go on tray with metal ties?
ta
metal tray with metal ties will look professional , but as a stummish said , You can find a cheap solution...
btw iv seen one time a SWA clipped by...hospitality saddles :
http://www.NoLinkingToThis/p/deta-galvanised-heavy-distance-saddles-25mm-pack-of-10/1177j
that was look funny but ...spot on :)
Would you be able to use P clips? Simple and cheap, but effective.
If you got the right size then you might even be able to fit one inside a cleat to make it look the same as all the other fixings, but I have not tried that and think they are the wrong shape to do it.
*I must stop thinking now.
Reply to swa- amd3 in the UK Electrical Forum area at ElectriciansForums.net
No waffling, going to get straight to the point. Main water on the exterior of the building in plastic. Changes to copper inside the building...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
I'm working on a system that has been installed incorrectly. It's a 3ph Hager board with 8 swa cables glanded into the bottom entry panel. The...
Hi All, Im quoting to install an EV charger (Dont worry - fully registered, but only been 2 weeks so i'm still picking bits up). Consumer unit...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
