Search the forum,
Discuss swa- amd3 in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
can you get fire retardant swa cleats?
for installing swa in a escape route that doesn't have a false ceiling etc
or would it just have to go on tray with metal ties?
ta
metal tray with metal ties will look professional , but as a stummish said , You can find a cheap solution...
btw iv seen one time a SWA clipped by...hospitality saddles :
http://www.NoLinkingToThis/p/deta-galvanised-heavy-distance-saddles-25mm-pack-of-10/1177j
that was look funny but ...spot on :)
Would you be able to use P clips? Simple and cheap, but effective.
If you got the right size then you might even be able to fit one inside a cleat to make it look the same as all the other fixings, but I have not tried that and think they are the wrong shape to do it.
*I must stop thinking now.
Reply to swa- amd3 in the UK Electrical Forum area at ElectriciansForums.net
