Discuss swa has been cut in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all
is it possible to re-join a swa because a little digger has cut it into two and if so what materail should be used
No problem mate, a simple jointing kit is widely available using a resin compound with a plastic casing. Conductors are through crimped and then the 2 part compound is mixed and poured over it into the moulded casing forming a totally weatherproof cast !
Reply to swa has been cut in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just wanted to know which people use. My case. Client converting attached garage into new rooms. Consumer Unit has to move to accomodate this...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Hi Guys After bit of advice please as we don't do much data normally, tend to sub it out. Had garden building this week which we'd run in SWA...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
resitting Saturday my am2 4 sections a3/b/d/e swa and sy failed on protective conductors on both swa i under stand thats the earths i...
