On some glands I don't think it matters which way the olive is but some it does. When I take a gland apart I ensure that the olive goes on the same way as it came apart. I have seen a few numpties just throw the olives away thinking they didn't need it!
If it's not the olive, and uve checked ure strands aren't to long - then to be honest, its probably just use mate. As an apprentice i did hundreds of these, and i remember getting so frustrated not being able to get them to bite - you've obviouslly gotta make sure the gland is completley square, and not trying to thread it on even a slight angle. Sometimes one of the strands can kink over abit and cause a problem.
As said, check olive and that strands aren't stupidly long. (if you take it apart, rememeber not to take the shroud off - its gutting when you've finally got it on without the shroud)
Think its probably just use though buddy as uve not done it ina while - as with a few things, take ure time and it'll happen Hope you get it sorted.
We've had some crap glands recently. Even when we've ordered the SWA and glands together from the same company (rhymes with MATT) sometimes they have just refused to go on. We've even resorted to putting CW50 glands on instead if CW40!
Lots of equipment now seems to be made with less and less raw material and as a consequence there's a lot of crap out there.
On a lot of old street lighting installs they used BS951 clamps to earth the SWA, there used to be a firm called TSS that made bright orange cutouts and there own gland plates with built in glands these didn't have a ring inside them.
Yes the CT gland made by a firm called Charles en Direct quite popular in some areas but where I've worked they won't entertain them.
Can also get the type of gland with the Tofco and Lucy lighting cut outs too.
