Discuss Swapping out these MG MCB's for RCBO's in the UK Electrical Forum area at ElectriciansForums.net
Hi all
Not come across this MG board before (believe Schneider now own these and some of there stuff may be compatible) I am looking to change some of these MCB's over to RCBO's can anybody advice on which ones may be compatible seems theres limited information online. Thanks
They are C45 series MCB's, the predecessor to the current C60 series.
Your best bet is to contact schneider and ask them, but I doubt they make anything to fit those boards anymore.
Thanks Dave I'll try to contact them tomorrow hoping I can source them be alot cheaper and easier to bring install upto standard rather than new dual supply board with contactor
But do schneider say it is OK?
Last time I spoke to their tech help they said yes and I doubt they've changed their minds in the last few years. I know this as we had a major customer query this as they had a lot of MG boards that needed RCD protection adding for socket outlets.
I'm not entirely surprised that they did say yes, that is good to know.
It very rare that you come across a C45 board like that.
I knew they approved the current devices for all of the previous C60 boards.
I think it because all they did was change the appearance of their kit when the re-branded which makes sense.
It will be quite a tight fit as the RCBOs are much taller than the MCBs, the original ones for this board were the same height but were more than two modules wide!
Sorry, John. Didn't mean to cause confusion. As long as the earth bar doesn't get in the way or come too close you should be OK.
Most of the MG/Schneider boards I've worked on have been vertical 3ph ones with plenty of room.
Reply to Swapping out these MG MCB's for RCBO's in the UK Electrical Forum area at ElectriciansForums.net
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
I may well need to change all the MCB's for RCBO's in this board (see picture). Do Wylex RCBO's fit in this board? It is currently fitted with...
8K
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Have an existing old client with what's best described as a sprawling small-holding of a property. There's an armoured external supply which...
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
