To avoid the relay, can you swap the starter contactor coil for a 240V one? They are often available separately and interchangeable. Or if not the coil, swap the contactor.
Heads-up re. the relay if you do use one to control the 400V coil : Traditional octal relays are not rated to switch 400V, typically they have a maximum rating of 250V, a few go to 300V. There are plenty of DIN-rail mount relays that will do the job but I do not think the one linked above is suitable unless it states otherwise.
I did offer to talk to you yesterday evening, left you my phone number, but no response, all in response to your original question, I guess you have your answer now and are no longer interested, so I will no longer be be part of this post, however good luck.
Will this work?
Really sorry Pete didn't realise you had messaged me. Thanks again for offering to help. I hope the drawing I have done is correct!
Don't want to sound negative but if you are asking will this work then maybe this is beyond your know how. As Rob says get someone else involved so you can see how it all works.
I did offer to talk to you yesterday evening, left you my phone number, but no response, I guess you have your answer now and are no longer interested, so I will be part of this post, however good luck.
Sorry for trying to improve my knowledge of starters...
It's amazing how in life some people try to help and some just like to put down.
I have worked with many electricians over the years and I haven't found one who knows everything. Some have had a sound knowledge and some have had excellent workmanship.
The little knowledge I have gained over the past 20 years I have enjoyed sharing and have never put down other electricians to make myself feel better.
All I wanted was a little advice........
RANT OVER..
To be fair you've had some good advice on this thread. But if a client is paying for the work to be done then they will expect someone who is comfortable doing it. Nothing wrong with knowing your limits. I don't mind admitting that I don't know the answer.
