dlt27
- Reaction score
- 26
Hi and thanks in advance.
I have been called to a job to look at a faulty starter for a swimming pool.
The starter apparently has never worked and swimming company has agreed to pay for it to be fixed ( there electrician has had 2 goes already).
The starter is supposed to be wired so that if there is a power cut the pump automatically restarts, also it is controlled by a 240v timer which also turns on 2 uv lights.
The starter at the moment never turns off by the timer and the reason for this I noticed straight away is that starter is a 415coil being controlled by a 240v timer.
The main trouble I've got is does anybody know if there is a starter with 240v coil and n/c contractor so after power cut it automatically restarts. Existing starter is Schneider LM35P714.Thanks again.
