Discuss switchboard in Hazardous area in the Electrical Engineering Chat area at ElectriciansForums.net
In Australia, we use TN-C-S system. I have a switchboard feeds a pump in hazardous area. I knew for switchboard in Hazardous area it needs to connect to a TN-S system. So should I remove the MEN link in the switchboard? Could anyone help me with this matter? Thanks.
Do not remove the MEN link. Do not do anything except bring in a consultant with EEHA (Electrical Equipment in Hazardous Areas) certs to assess and advise on this job. If you do any work on HA gear are you willing to lay your license on the line that it's all to standard? Because you will be.
Removing the MEN link does not convert the supply to TN-S, it converts it to DANGER-OUS.
Reply to switchboard in Hazardous area in the Electrical Engineering Chat area at ElectriciansForums.net
Fluke MultiFunction Tester 1662 TNS Earthing system. Switchboard - 415v - 3 Phase + Neutral + Earth. MCB 1000A 3 individual Earths (185mm)...
We have a meter EDMI - ES30B fitted to our property. I understand from the fact sheet for the smart meter...
Now Ive done Periodic Inspection and Initial Virification Qualifications with LCL/EAL (so non C&G 2394/95) # strange part building Modules , this...
I've been installing Type 2 SPDs in consumer units for several years now, and they always come as a pair, connected across L & E, and across N &...
And now for something completely different! I have been after a power station telegraph for decades and due to the fact most would have been...
