Discuss Switched fuse isolator in the UK Electrical Forum area at ElectriciansForums.net
Skys
I have got to install a switched fuse isolator with 25mm tails and a 3 core 25mm armoured. Any recommendations on an isolator? Always struggle with isolators twisting and generally just not enough room.
If money not such an object then also the likes of these:
But not very likely for domestic use!
That looks like it might be perfect. Looks like there will be plenty of room. Cost is not a problem for this job customer just wants it doing right
This is worth a look.
https://www.NoLinkingToThis/p/wylex-100a-domestic-switched-fused-unit/5290J
It's basically a 'tails' unit in a bigger surrounding box. Fair bit of room. The main issue is while L and N can be up to 35 sq mm, E is only 16, so you'd have to connect the Earth outside the central bit. 303mm high, 179mm wide.
I have used the wylex one listed above and it wasn't too bad but I only had a 16mm 3 core Swa, I ended up lugging and bolting the earth's as the terminal in them is poo! should be ok for a 25 with some neat bending.
I have been using a switchgear solutions one from Edmondson for the last few jobs, these were well built units with plenty of space (managed to terminate 35mm4core in the 3phase version) but can't seem to find them listed.
I like the bigger metal clad units if you have the room.
Reply to Switched fuse isolator in the UK Electrical Forum area at ElectriciansForums.net
Should a small 500W electric rad on a fused spur also have an isolating switch? Some of these small rads have fancy timers that might get...
Hi I replaced a Flash immersion timer with an apt one today and it seemed straightforward but just wondering should the light on isolation switch...
Hi we have been asked to run a 3 phase supply into a boiler house to feed a DB fed from next to the existing meter. Would we need to install Tails...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
