N
nathansinar
Hi guys new to the forum and will introduce myself shortly
I have attached an image of a spur i have taken as you can see from the attached image
I am doing a trainee maintenance engineer role and just wanted some info on the below.
1.) when using sy cable do you have to earth the sheeth? i have had various reponses saying it is good practice but you can get away with using the cpc inside the cable and that alone?
2.) in the image i have posted becuase the sheeth hasnt been used an earth from the the spur to what ever it is feeding, does an earth need adding from the back of the spur plate to actual spur box as it could become live?? is it a reg that this needs to be done?
Thanks for help!
Nathan
Thanks for help!
Nathan
