N
Newbie90
Hi all,
I know tails are meant to be less than 3 metres in length and if not then a switch fuse needs to be installed.
What's the situation when the tails from a flat go from a communal hallway then into the consumer unit? (Approx 5m)
Do you just put a switch fuse next to the meter? (The run goes through the loft space)
