G
Guitarist
It's a real issue that so many electricians are not familiar with using SWA. Probably why I keep finding the steel cut off and taped up at the ends....
If temp supply, would it be easier and cheaper to use SY rather than SWA?
Making off the glands on the SWA is not this issue that's quite within my capabilities , it was the size of the cable that was the query?It's a real issue that so many electricians are not familiar with using SWA. Probably why I keep finding the steel cut off and taped up at the ends....
And whats the reason for that, just because I don't spend my days slinging 160mm four cores on cable basket im a D.I.Y'er now ? Im assuming the hummble ("house basher" ) is below the scope of this forum then?This should be in the DIY area
you'd need to enclose it in scaffold tube to make it builder proof.:death:
I think that's down to DIYers rather than sparks
