It's a real issue that so many electricians are not familiar with using SWA. Probably why I keep finding the steel cut off and taped up at the ends....
Making off the glands on the SWA is not this issue that's quite within my capabilities , it was the size of the cable that was the query?
Im inclined to agree SWA is the better cable to make it builder proof.
you'd need to enclose it in scaffold tube to make it builder proof.:death:
This should be in the DIY area
And whats the reason for that, just because I don't spend my days slinging 160mm four cores on cable basket im a D.I.Y'er now ? Im assuming the hummble ("house basher" ) is below the scope of this forum then?
Just on the basis none of your posts have demonstrated much competence, knowledge or experience!
Dam your good , a hand full of posts on a forum and you have summed me up well done chief.
Tel I like that one .
But do you honestly think that would still be enough to keep the common lesser spotted hairy arsed knuckle draggers away from their natural prey ( shiny shiny magic stringy thing , ugg ugg ) !
and it's not a good idea to lay the cable days before connecting. TB will have it away in the back of her mini. ( the cable, that is). :toilet:
BW is black and white and CW is colour and white. ... ssimples.
