plan to install a 70mm swa into a 3 phase board.
my idea is to install a schneider acti 9, 3 phase board, with standard incomer etc, and install a schneider extension box below it. incomer or mcbs will only take say 25mm, so planning on using the extension box to reduce the 70mm swa down to say 25mm or 35mm with inline shearbolt connectors with heat shrink over. Thought using these i wouldn't need a hydraulic crimper. Do these conductors need to be fastened back via din rail, or is my method acceptable? whats your thoughts?
