how will that not be proffessional? i make off into a box.. keep the tails long and rather than SLOT the cover.. which comes off completely... or chase out the wall...i will pack out the CU off the wall so i can come in the premade back entry... i dont see the problem?
Its good that people can come on here and ask for opinions and debate without being chastised..
Mark, do you really expect to come here and state you will do something that looks like a --- on your head and not expect a rebuke?
Come on chap, I sincerely hope your standards are better than that.
slot the cover. as long as the ad. box is close up to the bottom of the cover.
Its all good... i asked the question because i knew it was not the 'proper' way to do it..theres not much armoured to work with and it is in the corner of a room.. if the cable was securely fixed to the point of entering the enclosure the danger was not as obvious to me as some are suggesting.. plus im not sure if i am going to have to make a joint in the box to extend it if i take the gland back that far...Would have negated the need for a joint.
This is a server room locked to all but trained personell so its not like i was doing this as an install in someones garage...
Still, i am going to do it as it should be done.... thanks for the advise.
Markc17 you are seriously rough, the firm you worked seen like utter dog sh!te too if that's what they think is good practise.
I have never done anything other than gland both ends of an armoured cable. Not doing it is rough, unprofessional and will look as rough as sticks. I can't imagine any scenario where it would be appropriate to omit a gland and if I were to employ people and they did such an appalling job they would be picking up their P45 very soon after I discovered it.
The guy I was apprenticed to would have knocked seven bells out of me if I'd done this.
Again, thanks for the constructive criticism. I did my time in a few firms.. my experience is what it is.. i didnt exactly have a great deal of choice who i worked for. As i said.. i have never made off an armoued before without a gland.. i was asking a question as to whether people ever did and i certainly got my answer.
Glad to be of service! :)
Have you got room for a Henley gland? :D
How about when you have to seperate the earths of the source with the new install? Nothing wrong in using a compression gland to support/secure the cable along with the cable cleats.
