Luminous
- Reaction score
- 3
Just looked at a job and it's all a bit of a mess. The easiest way to leave the customer with like for like and comply is to use the existing cooker (21a) radial (6mm 32a) then put in 4mm to a socket then 3 amp fcu to 1.5mm for hood.I'm sure this will comply, but what size cable do you write on the cert? 6mm or make a note and put them all down?
