Discuss "The Great Debate" - Plug Top or just Plug? in the UK Electrical Forum area at ElectriciansForums.net
I fear that all this conversation about electrical accessories has just turned into a mass debate - good to see @GeorgeCooke out of his cave post hibernation - someone feed him some honey please
No. It is a plug for a bath (you would need to quote the size in mm).
It is a plug for an electrical device (you will need to quote the size 5A, 15A, 13A etc and the fuse value if the latter).
So E.G. I need a 35mm plug for my bath, preferably white.
OR. I need a 13A plug with a 5A fuse for my table lamp.
I'd always fit a 3 amp fuse for a table lamp.
With incandescent lights a 3 amp fuse will often blow when the bulb fails, a 5amp one won't.
But the fuse is to protect the cable not the lamp on the end of it.
As you say: some Electricians aren't very bright.
And how many table lamps actually use old GLS filament lamps these days, very few I'd suggest. All the table lamp manufacturers who fit 3 amp fuses during manufacture can't be very bright either I suppose ?
what about the lamps/bulbs along the circuit, not at the end? don't they require protection also?
The 3a fuse is a habit from pat testing where rewirable plug tops on items <700w should have 3a fuses. Anything else 13a.
Although a 750w led bulb in the table light would make me a very bright electrician indeed.
It would certainly make it easier to see while I'm terminating my satellite cable.
Not many I agree. You are right about manufacturers. Most don't know the fuse is to protect the cable not the lamp on the end of it.
Reply to "The Great Debate" - Plug Top or just Plug? in the UK Electrical Forum area at ElectriciansForums.net
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
Hello. I will be buying new apartment to live. But electrical plugs are older. Not the newest. And my question. It will be fine to plug pc in this...
I am moving my dryer to a different room and need to add a 220 plug. Can I tap off the existing plug to add a 2nd plug in a different room? Here...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi, I have purchased a piece of equipment from China and we are required to finish the final wiring. They have supplied a length of 3 core 6m...
