Discuss Thermal Insulation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Scott F
Been to see a job new build which has blue polystryrene bricks ,has any one had any experience with these. did you wire the rings in 4ml for instance any advice apprieated. Also has any one have experience with class b cat ld3 fire alarm systems .Are they fairly simple to install or am i better off getting fire alarm installers in cheers
poly blocks, you need to contact the manafacturer, (or a cable manafacturer) as a rule never let cables come into contact with polystyrene as it reacts with the pvc cable, you may have to use specialist cables?
I've not heard about polystyrene reacting with pvc before.Where did you read about that.I wouldn't mind reading up about that myself.
Did a major kitchen refurb years ago that had wood panelling backed by thin polystyrene sheets.
The cables that it covered were practically glued to it.
As far as i know its not mentioned in 7671 (certainly can't find the little rascal mentioned), its more of a building regs thing, if you google the key words you will find out more, insulation manafacturers worn about it (gypsom) , some polys are ok ie polyuerathane (spray foam) but polystyrene is a definate no.check what your blocks contain.
I have had this myself, i pulled up a water damaged chipboard floor layed on slabs of the stuff, it had only been down about 18 months and the cables that passed through it had already gone black and gooey.
I searched this forum and found this.
"In pvc cables a plasticiser is used to keep the cables flexible and its this plasticiser that migrates on contact with polystyrene causing the cable sheath to become sticky and eventually brittle."
sounds interesting
ive got to rewire a kitchen in a few weeks that is having poly backed plaster board fitted.
thanks for that
wow that sounds scary and I've seen polystyrene used as insulation loads of times without precautions taken,they must all be in the same state as yours by now.:(
cheers for the links lennie do you install these your self? fire safe products that is . If so am i right in that commisssioning is just filling in the certs and testing the smokes am full scope and hold 2391 so deemed competent in some peoples eyes
Reply to Thermal Insulation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
I'm installing mag-locks and fire door hold-open magnets at the moment and I'm wondering if any of the cable should be fire performance cable...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
