Discuss Those bloody foxes chew my plug in the UK Electrical Forum area at ElectriciansForums.net
Gringoking88
Hi all,
just wondering if anyone can tell me where I can get a replacement plug as shown in the pic as the foxes have chewed through it. It goes to an AC adapter for chriChris lights .
Many thanks,
Martin
I doubt it is user replaceable, these are normally a moulded part of the festoon/cabling assembly. If you do replace it, you would also need to heat shrink it or similar to give it some degree of IP. Probably best to buy a new set of lights to be honest.
agree with marconi. if the lights are LED, might need to get polarity correct. and put some chicken scraps out for the foxes. they need to live as well.
It does look like the old DIN 41529 audio form factor but that plug had the rectangular pin in the dead centre and the round pin offset quite some way. Your pins are both offset from centre so it's probably a propriatary plug based on 41529.
Reply to Those bloody foxes chew my plug in the UK Electrical Forum area at ElectriciansForums.net
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
Hi all, Just looking at starting some testing since newly qualified, don't know if this is a stupid question or not. Is there an allowed...
