What Tel said, simples as they say.
I think I might follow this route, but will get somebody to check the machine who knows a bit more about it than I do. But I think at this time any emergency stop button is better than none.
Thanks for all the great advice as usual.:hurray:
I understand your thinking but I would strongly advise you get someone to look at it and advise you beforehand rather than the other way around. I fully understand your thinking about an E-Stop is better than none but unless you are taking the band saw out of use until it has been upgraded to regulation and inspected for compliance then either walk away or ask for supervision.
I see it all too often, this falls well outside of the BS7671 so only should be carried out by someone compliant with the appropriate standards...
The advice you are taking here may give you a functional solution but it may not be compliant or fail-safe and if anything did happen after your alterations then you would be fully liable and your insurance would be void unless you specify your involvement with machinery control and critical systems at the time you took your insurance out.
This is not the same as asking for advice about electrics within the BS7671 where you may have lack of experience in a certain area this is an area where you are probably not insured to carry the work out and is outside the scope of the BS7671 (guessing your not insured from the nature of your query).
It's only going to be useful if there is someone there to push it quick enough!
Preventing the accident in the first place is far better than anything else
No it's NOT.
By fitting it you are implying that if used the machine will come to an immediate and safe (as possible) stop.
You, or anyone else on here cannot say that without intimate knowledge of the machine.
Leave it alone till you or whoever is going to carry out the E.M stop installation are CERTAIN about what you are doing.
Hi all.
I’m after a bit of advice regarding emergency stopping. I’m carrying out some remedial work on a building where it was noted that an hydraulic band saw had no form of emergency stop. The machine is started by it’s own start button, but relies on a stop leaver to activate when the cutting arm of the saw drops. If there was an accident, then the machine wouldn’t stop until you reached underneath and physically pressed the stop lever, or when the arm had fully dropped (a little too late then!).
I wanted to install a simple three phase latching (twist to release), emergency stop button to disconnect all three phases, but have trouble finding one. I didn’t want to install a DOL starter as there would be two start buttons for the machine (unless you left the DOL or band saw started on).
Any advice would be much appreciated.
Is this machine CE marked?
This job is turning into a headache! I work for a large national electrical contracting company, and this was my job for tomorrow, based on somebody else’s recommendation. I just wanted a bit more background information before I did it, but it doesn’t seem it’s going to happen now based on what’s been said.
We're all just trying to make sure that you don't drop yourself in it. No ones trying to make it anymore difficult than it needs to be.
I really appreciate the views on here. Think a call to the office tomorrow will be the first thing I do before taking out my tools.
I could always do my second job. Have to re-terminate some MICC.....is that just like stiff FP200!!!!!!
I think that's a wise decision. I would at least request guidance for this work from someone with intimate working knowledge of the machine regs who's prepared to take legal responsibility for the design.
It might be better to leave the controls alone and add extra guarding to prevent accidents.
