BigSi
- Reaction score
- 55
Hi all.
I’m after a bit of advice regarding emergency stopping. I’m carrying out some remedial work on a building where it was noted that an hydraulic band saw had no form of emergency stop. The machine is started by it’s own start button, but relies on a stop leaver to activate when the cutting arm of the saw drops. If there was an accident, then the machine wouldn’t stop until you reached underneath and physically pressed the stop lever, or when the arm had fully dropped (a little too late then!).
I wanted to install a simple three phase latching (twist to release), emergency stop button to disconnect all three phases, but have trouble finding one. I didn’t want to install a DOL starter as there would be two start buttons for the machine (unless you left the DOL or band saw started on).
Any advice would be much appreciated.
