Currently reading:
Time clock on ufh
Discuss Time clock on ufh in the Central Heating Systems area at ElectriciansForums.net
cliffed
Supporter
Plumber wants time clock to switch on ufh,it's a heatmiser system with all controls,including neo stat programmable stats.
All these stats go back to control box, for actuators.
problem I see is that this box needs a permanent live supply,a time clock complicates the connection,any ideas.
Exactly that's what I've told him,he wants a definite off control.
The programmer he's supplying is a norm 3 channel one,no inter connections at the heatmiser box,it's for ufh,radiators & hot water,that's not a problem,it's just configuring the time clock into the ctrl system.
Cheers
Put the time clock to the two port valve if it has one, not ideal though. Then set the neo stats to non programmable (00 on function 12 in the set up menu)
Reply to Time clock on ufh in the Central Heating Systems area at ElectriciansForums.net
