T
trev pow
im fitting a eletric towel rail in the bathroom via 5amp fused spur and i need to fit a timer to this, can the timer be fitted next to the fused spur and if so how do you connect the timer to the fused spur ? any help would be great thank,s...
You can pick these timers up in some wholesalers, dont often see em though. When you get it refer to manufacturers instructions on how to wire ut in.
Easy. :)
Sent from my GT-I9100 using Tapatalk
only done this once before. fitted immersion heater timer in loft directly above FCU. supply from RFC to FCU, then 3 core/E to timer, 3rd core as sw/L connected in FCU back box to heater.
but are they suitable for fitting in a steamy bathroom?
Mmmmmmmmhhhh... probably not, I still have instructions somewhere will check later today.
OK, couldn't find the instructions, so had a look here:
SupplyMaster 7 Day Fused Spur Timeswitch | Timeguard 2010
... no mention of IP rating at all, even in PDF download, so I would say definitely not. Not something which I had to think of when installing these last week, as all the fused spurs I replaced wer outside the bathrooms.
You'd think they would do a nice clear silicone membrane to fit over it which would help.
I'm assuming the OP's FCU is outside the bathroom, at worst it will be outside any zones inside the bathroom so IP rating isn't a concern. The manufacturer has no specific instructions as to the positioning of the unit so I doubt it would be a problem where you installed it, regs permitting.
Sorry to resurect this old thread!
However,
I am also on the hunt for an IP44 timer for a towel rail.
I have found a few switches/controllers but none are timed, can anyone reccomend one????
Thanks,
James
However,
Thanks,
James
can you not fit an immersion heater timer, out of the bathroom,maybe on reverse side of wall?
trev pow,
cbw,
