Discuss TN-S high Ze in the UK Electrical Forum area at ElectriciansForums.net
The dozy bint will only be able to answer "Computer says naw"but he needs to get put straight through to the duty engineer....
not some dopy, obnoxious bint on the end of the phone....
look, they have a duty to the phone company see...more likely the dozy bint will give you an alternative number that is programmed to play incessant frank sinatra garbage till you get fed up of holding.
in future you may be given options to press...
choose from:
.8
.35
21
Whey thas them caal senta thingys intha toon ye knaa, wu aal talk propa hea an ye cin unastend wu perfect.that's half the problem with everything today. you sign up for something with a british company, everything is OK and then you get a problem. so you phone the 24 hour help line and get talking to someone who sounds like the punka wallah. can't understand a word.
agreed...its cheap n slovenly..you don't rely on RCDs for disconnection times if at all possible. it's a poor DNO earth. let them sort it, then you can get your testing done.
are you sure you dont work in a call centre trev?Whey thas them caal senta thingys intha toon ye knaa, wu aal talk propa hea an ye cin unastend wu perfect.
Barry, I scent blood. Yours, very soon with the mood this lot seem to be in. A RCD is NOT the solution. At best it's a quick bodged fix.
Reply to TN-S high Ze in the UK Electrical Forum area at ElectriciansForums.net
