Search the forum,
Discuss TN-S high Ze in the UK Electrical Forum area at ElectriciansForums.net
Just as a side project mate. Got to keep the wolf from the door :)
sometimes when i come home in a bad mood...i howl at the moon....
Barry, I scent blood. Yours, very soon with the mood this lot seem to be in. A RCD is NOT the solution. At best it's a quick bodged fix.
I don't know Tony, There are a few here that seem to think an RCD is the ''cover-all'' answer to non performing TT systems!! When you think about it, it all boils down to exactly the same thing!! lol!!
We have said, get the DNO in to improve the earth, ring them up, and in the meantime whilst waiting if your concerned install an rcd
Reply to TN-S high Ze in the UK Electrical Forum area at ElectriciansForums.net
Evening Chaps As can be seen in the attached photo , the incoming supply cable has a Earth soldered to the outer sheath of the cable suggesting...
On an EICR I found a 200 amp 3ph supply, TNS earthing (which looks original) and Ze of 19 ohms. No rods. No RCDs. L1 -> N was about 0.5 ohms...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi, Any suggestions what this black cable is coming off the supply's incoming cable? Its a TN-S system, I thought it could be the earth conductor...
I have come across what I think is a looped supply - like a normal incomer but two of them coming up side by side. It's a TN-S arrangement with an...
4K
