Hi all, just wanted to see what the collective thoughts are on readings obtained when testing end to ends on a ring mains cpc’s. If I were to use the 1.67 calculation for a 2.5/1.5 twin and Earth cable, what kind of reading would people allow to be recorded before considering coding it on the cert. Would you code it if the results obtained don’t match the 1.67 calculation exactly or would you allow a 10% tolerance?
