Z
zap
http://www.neweysonline.co.uk/neweys/pdf/WI00_Torque_Setting_Data_Technical.pdf
The above links to document containing various manufacturers product torque settings. I hope it's useful to someone.
Further more, to my knowledge, there are only two vde torque screwdrivers on the market: Wera and Wiha, neither of which satisfy certain torque values presented in the above document. i.e. < 1 and >5 Nm or <1.2 and >3 Nm for t'other. How are we supposed to comply with manufacturers instructions if the tools are not available yet?
NOTE: I haven't checked the document against the manufacturers figures.
A cursory look at that Neweys table, there can only be a few % that are outside 1 - 5 Nm range.
If one really had to tweak fixings up to those settings, I guess you'd have to get your hands on extra drivers!
It's only threaded / nut terminals which require more than 3Nm, so you'd be doing that with a conventional torque wrench anyway. My torque screw driver (hex bit adaptor) goes up to 4Nm and cost me about £30 if I remember rightly.
I do have conventional torque wrenches from my mechanics days. However, the settings of less than 1 Nm could be of concern.
Is the £30 torque driver still available at or near that price? If so, where?
Thanks for all the comments...
Tbh, it was a deal at a wholesaler and I've no idea (can't remember) what the brand is. I'll dig through some old tickets and see if I can find it. It's not insulated though, but then, we don't work live, do we?
draper ones on ebay 1-5Nm. £48.
OK I’m old fashioned. Why in the name of god do electricians need torque drivers? If you can’t tell a terminal is correct by feel then go find something else to do.
Because there are too many scaremongers out there, that think the slightest mistake and you will end up sharing a cell with Winston who has committed mass murder and likes to induct the newbie in "B" block with his own special type of man love.
Let's put it like this: I KNEW my first wife was a nutter, but I still had to be able to prove it in order to get divorced.
Thanks all. I'm £75 lighter but can at least prove that I've got the tool for the job if and when asked.
